'04 Factory Cd Play Will Not Eject
My 04 Chevy Silverado's factory cd player will not eject anymore. All it does is make a clicking sound. Anyone know how to fix it or at least away for me to get the cd out?
I'm new here and found this site while Googling my problem, been wanting to find a GM specific discussion forum for while now. Glad I finally found one. :thumbs:
you will have to pull the radio out and pop the top cover off and get the CD out that way. The unit is junk unless you can get someone to repair it for you but in most cases it is cheaper to get a new one.
Let me know how it goes, I've got a couple of stock silverado cd players I've been trying to get rid of
    rayredbone
    rayredbone
  • Who's Online   4 Members, 0 Anonymous, 318 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
