P/s Leak Fix
Gentlemen,
Time for this post again. I have a friend that had a bad p/s leak at the rack. Really bad. I gave him my standard advice, Add half a can of STP engine oil treatment to the p/s system. As usual, it worked instantly stopping the leak and quieting the system.
This is the eighth time this has worked flawlessly. I strongly recommend that you try this if you have any p/s leakage. I might not do this if you live in the arctic but it does work amazingly well in normal areas. Quiets the pump too. It is essentially free and does no harm.
Ken
