Radiator Quesion
grose67
Ever since I replaced my intake gasket, I have been pestered with coolant leaks. I figured out one of the leaks was coming from the heater hose and got that fixed. Now I have found that instead of pushing coolant into the resevoir tank, it is pushing it past the radiator cap. I replaced the cap when I replaced the gaskets.
What would cause the coolant to be pushing past the cap instead of into the tank?
Are you sure you have the correct cap?
