-Wardster
You reminded me. I can't use the line "the house payment sits in the garage anymore" as I paid Blue off in January and managed to save up some cash to get a place built.
I actually own the apartment building I live in, so the truck is the only payment I have to make. I could actually buy a pretty big house for the same money, but I am content with where I am. :)
  • 1 month later...
Funny i saw this thread on the eve of leaving to go on vacation at our 2nd home in Madison Ohio. hahaha
Right on the lake baby! :chevy:
Right on the lake baby! :D
How long will you be in Madison for? Unfortunately or fortunately depending on your view, I'm in Vegas until the 1st of Sept. or else we could've perhaps arranged a little OH/PA gathering.
  • 9 months later...
Stay away from TOTH in Akron????? What a joke they Are. I'll stop there becausem
my kids are in the room.
Edited by Rookie
  • 4 weeks later...
I love quaker city. i used to go there most week end befor i converted to trucks. Norwalk still is the track all tracks should be designed after. Used to own a 77 monte carlo 10.52 @ 122 MPH in the quater mile. o yea i almost for got all motor!!!!!!!!
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 700 Guests (See full list)
