Header Gaskets
so about 6 months ago roughly i installed shorty headers on my truck and now the gaskets for the block are completly blown. Its pretty annoying driving around town with that exhuast leak. Does anyone know good gasket to be using thats gonna hold up instead of those gaskets that came with the headers? Thanks
Cometic makes some pretty slick gaskets...but you would have to check your port size.
http://www.cometic.com/domesticauto.aspx
  • 1 month later...
I actually helped a buddy of mine change the header gaskets on his truck today and remembered why I'll never buy another set of headers lol. He's had a problem blowing them out as well. In my experiences with headers I've always used aluminum or copper gaskets and thread locker on the bolts. Backing off bolts always seem to be the culprit behind blown gaskets.
No offense, but blown header gaskets generally mean that the headers were either not installed properly OR the mounting flanges are not flat.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
