Hi Guys- I would like to get some bed rails for my truck. What is a recommended brand for these? Also, where have you been getting them from? Any deals going on right now that I should jump on?
Thanks in advance!
Jeff
i have the oem ones, they are decent my only gripe is that the tape that holds them on dosen't hold up real well over time but besides that they work great
http://www.paulfrancispaint.com/servlet/Detail?no=42
http://solutions.3m.com/wps/portal/3M/en_U...JbeVBZCZCKZL4gl
3M Automotive Acrylic Plus Attachment Tape - 06397
try to find the .060 thick Tape - not the 0.045 which has come loose after about a year
I'll admit the stock side has kept its shape and held well ,, the one i keep having to remove/replace - i f*d up the install and had to remove - found the 0.45 tape and stays for about a year ,, i figure the 0.060 should be a better match - close the same thickness as the OEM
I've got the oem ones on my 08 and haven't had any problems at all....
wait, define bed rails. because i think of these:
and theyre not held on by tape. mine are "putco locker"- they have a thousand pounds of tie down strength at each corner and are made of stainless steel. the black has been discontinued so theyll be hard to find (i bought the last set on amazon, and stylintrucks and 4wheelparts were out of them).
Agreed the pics are "bed rails", the stick on stuf are "rail caps". I like the ones in the pics better than mine, but mine are stout stainless steel also and I paid about $100 for mine in '05. There are a lot of different ones out there, mine anchor at the stake holes, they are also the second set I've had, had 'em on my '03. Try Penn Ind. in OKC they carry about 5 different brands/types/configs. Watch out buying stuff like that on ebay, your gambling.....
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,180 Guests (See full list)
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
