New Guy Looking For A Programmer
hi all. i have an 05 gmc 2500 hd with the 6.0 gas. i am wanting to know what programmers you guys use. i am looking to gain power for a 6 inch lift with 35 in tires. shift points aren't necessary as i have the 5 spd manual trans. any input would be greatly appreciated thanks!
www.blackbearperformance.com
All you need to know
gee thanks sounds like a big pain in the ars to me
How so?
I have no ars pain from going with blackbear... btw
Do I detect sarcasm when I was trying to help you?
I will change my suggestion then. Try the search function. This topic has been ran into the ground. The answers you are going to find boil down to this. If you want to pay more a canned tune and get less performance then get a handheld. If you want the best the get a custom tune.
sorry man!! guess i just didnt understand how it works. i will check deeper into it, i would like the most power available. i bought it lifted already. just seems like it should run better to me. my older 350's would run it into the ground, maybe i got a weak one who knows?? again sorry i'll clean it up i really do appreciate your thoughts thank you
If you truly want the most power available then a custom tune is the way to go. BlackBear travels all over the US and does Canada too, custom tuning everyones ride to their liking. There are other custom tuners around but BlackBear has alot of great reputation and does amazing work. I didn't realize till after I got my BlackBear tune how many shops and places just within a 50 mile radius of me do custom tunes. Def the best option for most power.
No problem man. :sigh:
It really is an easy process and Justin (Black Bear) is great to work with. He and Jenna can walk you through everything.
Best thing to do is see if there is a live tune session anywhere close to you. That makes extremely easy and adds a little fun too.
right on! thanks guys!! i will deffinately have to get ahold of him. sounds like the best way to go!!
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
