Water In The Fuel System
well well well my troubles never end i put up a post saying my 05 duramax was running on 4 cylinders (thats what it sounds like anyway) well i thought about it and said heck there might be water in the water separator so i went out side and sure enough drained water off of it so i said i will install a new filter completly oblivious to the little problem i just now have come to see i was reading the instructions to the new filter wanting to make sure i did everything right well i said to unplug the water separator from the harness well i was thinking i didnt see any wires comming off the water separator and then it hit .......ive got water in the rest of my system. you see im fairly new to the diesel world and i didnt know ive learned alot about diesels lately however the jack a$$ that owned the truck befor me dont know what he was doing either because he musta cut the wires and unplugged the harness because its not there i would totaly love to strangle that guy so anybody got any ideas on how to get the water out of my injectors and the rest of the fuel system i know im always gona have moisture in the fuel i just need to know how to get rid of it between the filter and the injectors so it will go back to running right.
