Attempting To Upgrade Stock Speakers
Just got the 2008 Silverado 1500 Extended Cab Texas Edition without the bose(which I am surprised since the other features are luxury)
The thing I don't like about about my new truck is the sound system, man it's just terrible. Wish it was like my Mom's '03 Tahoe w/ Bose. I can't let my mom have a better system then me(she has that stock 10" sub).
Here is what I plan on putting in.
Infinity Kappa 62.9i(front and back) - http://signature.crutchfield.com/s_108629I...appa-62-9i.html
Kenwood KDC-MP345U - http://www.crutchfield.com/p_113MP345U/Ken...KDC-MP345U.html
I want to replace the front and rear, but everyone at crutchfield is saying that the rear mounts were built really weird in my truck. The speakers come with brackets, but for the rear doors it says it may not fit. Anyone have experience with this? Was it hard?
I plan on using the stock wiring and getting a wire harness from crutchfield. Also getting the GM factory adapter from them.
Side question, offer they gave my before TT&L and stuff was $21,750(and a "free" spray in liner added today) and the truck has 49k miles. Did I get a decent deal lol?
Kyle - i just did my front/rear speakers in my ext. cab Sierra. The rear OEM speakers are a 5.25", sitting in a large rectangular bracket. I made a bracket out of MDF wood and mounted 6.5" speakers back there. So yes, any computer will tell you "no fit" because of the odd shape. It is very easy to do, you will need either a 6.5" speaker bracket adaptor, or build a bracket out of wood or plastic to fit the factory rectangular shape.
Not a hard job though. good luck. i have a picture of the opening, but its on my cell phone. PM me if you want me to text it to you or email it to you from my phone.
those brackets would suffice...but you'd still have a gap from the rectangular hole. you'll see it in the pic i emailed you.
if you are going to buy those brackets, i'd recommend buying some dynamat to fill in the rest of the gaps so you have a nicer seal so no air leaks out sacrificing sound quality.
nah the fronts are your typical round opening. you will still need some sort of bracket to make it to where you can screw in the mount. i actually found a picture of it on my phone that i'll email to you of the front.
unfortunately its just a picture of the speaker mounted, but you will see the bracket i used as an example.
to get them in temporarily since i did not expect that rectangle hole, i used dynamat and the same bracket from the front speakers i sent you the picture of to fill the gap.
i bought some MDF wood and will be making a rectangular bracket to hold the rear speakers. ill post pics when im done
I think I will go with one of these two decks instead.
http://signature.crutchfield.com/S-YHW9l8k...=5684&avf=N
http://www.crutchfield.com/p_158GT640UI/So...DX-GT640UI.html
I found the sony originally, but somewhere someone told me to get the Kenwood. I forgot which site and I can't remember why they said it was better. I think it had to do with the XM Radio. I can't figure out on the description if one supports it or not though.
Can you cut dynamat to fit your needs? I'm seeing if my buddy at best buy can get it at a low price. But it's 5 18x36 sheets of Dynamat Extreme
The Kenwood deck is available from Amazon for $138. It is shipped from a company called AUDIOSOURCE. I have purchased from them in the past and they are outstanding to deal with. The Kenwood also has the ability to add XM and Sirius with an optional accessory. I don't know this for certain on that module, but on my DNX-9140, the HD Radio, XM and Sirius all use the same rear input. So you can only use one of the three at ant given time. If you want to change from say HD Radio to XM, you would have to remove the unit and physically change the input plug. I only use HD Radio, so it isn't that big of a deal. Between that and my iPod, I don't have a need for XM or Sirius. You can cut the dynamat to what ever shape you need.
Kenwood KDC0X494 on Amazon for $138
yeah you can cut the dynamat to contour to the vehicle door
Is there a big difference between 18 rms and 22rms? That is the difference, Sony 18, Kenwood 22. I am still not sure which one to get.
I like the sony better, it has RDS which shows the artist/song when playing the radio, but I want sound quality over features.
I'm not a fan of Sony car audio products in general. They are decent entry level decks, but that is about it. The Kenwood is significantly better and will produce cleaner power longer. The Sony will likely tire quickly if used at higher volumes for extended periods of time. This is just what I have seen, not fact. It isn't like the Sony is a bad unit. If you like it more, then go for it.
I agree 100% with this.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
