I thinking about getting a Line-X for my truck. I live in southern MA and would like to know if you guys recommend a particular dealer in the area. Also, what should it cost me for Xtra in the under the rail style?
All Line-X work should be backed by the limited lifetime warranty, so you should be good anywhere, as long as they're a licensed distributor. I just got mine done today - turned out AWESOME!
Im scheduled to get mine done in marlborough, ma next week. They gave me a standard price of $550 for an under the rail spray. I chose them because I like the line-x look and they dont require me to leave the truck overnight. I drop it off before 9 and its ready by 430
Let me know how it comes out and the final price. Are you getting Line-X Xtra? I'm interested to hear about North Shore Line-X in Salem as well since it is about the same distance from me as the one in Marlborough.
will do. What is line-x xtra? havent heard of it. I will take some pictures and post them here. Im going on the 14th.
http://www.linex.com/xtra_6.shtml
