16's To 19.5's On K2500 . . .
BigBlockV6
The wheels:
The tires:
My truck came with 235/85r16's i went to 7.50-16's to get better traction tread style's the 235/85 is the same size as the 7.50 32" ish x 7.8-8.2" ish anywho . . .
I want to go to 245/70R19.5's, the 245's measure 33.3" x 8.8" will they fit a 95' K2500 ?
should i swap my 4.10's for 4.56's ? for extra grunt ?
Keep in mind i have that 6.5 turbo it thinks its a diesel so extra gear is a plus :jester:
Mike
  • 2 months later...
I would think they should fit as long as the offset is right. Sorry, cant help you there. But with that said, if you want it to run at least as good as you do now, I'd consider regearing but I'd skip the 4.56's and go straight for the 4.88's. You won't see enough of a different to justify the cost of the gear swap with 4.56's over 4.10's.
:P
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 699 Guests (See full list)
