i have a surging problem on my gmc 1500 1992 4.3 it will surge at steady speeds. this will be only after it has been drivenand after the enging is at full temp. and it is shut off and restarted will it surge. i can drive it 200 miles will run fine till it is shut off then restarted will it start surging. it can be turned off onlt 10 minutes. i have replaced fuel pump. fuel filter , plugs egr selinoid, egr valve used distributer. net dist pick up , cap rotor. cant find a vacuum leak. im at a loss.check eng light does not come on. any ideas ? oh 305.000 miles on it.
I'd hit the throttle body with a can or two of throttle body cleaner, and while you're doing that, disconnect the battery and let the computer reset itself to the lack of carbon you'll create by cleaning the throttle body. You only spend about 6 or 7 bucks on the cans of cleaner, which if it has 305,000 miles, I'm sure it needs to be done.
No, I usually buy the store brand of whatever auto parts joint I happen to be in at the time....
thanks will try than monday.
what i can not figgure out is why it will only surge is after i restart it .when the engine is at or near normat temp. if it cools down below say 125* and restart it if will be fine. it idles fine put the gas to the floor its fine but at a steady speed it will start surging . i have used luckus(sp)in the tank 3 times no change.
check for a vacuum leak when your at temp. on older vehicles that used a thermal vacuum switches it was a common issue. engine ran fine until the switch opened and caused a leak some where in the system.. also ..you may be getting a bad signal to your EGR
good luck
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
