Non Bose Upgrade?
Well just bought my truck but looking to upgrade the audio to a aftermarket double din dvd unit maybe navi as well but just have a couple questions. I currently have a non bose stereo and my question is if I upgrade and buy the PAC harness I can keep everything butmy XM radio correct, still keep Onstar since it is free for the first year. I was leaning towards a Kenwood 6160 or something along those lines
don't hold me to this, but i think you'll lose your bluetooth phone connection if you have that. You'll need to make sure the new headunit has it.
I dont currently have blue tooth but new radio may. But Onstar will stay intact with that harness correct?
if you have Steering Wheel controls, you have Bluetooth if it 2009 or 2010. as far as the OnStar, you need the GM harness from Crutchfield and that will not only keep you OnStar working but it will keep your door chimes and blinker sound working as well.
if you have Steering Wheel controls, there's a harness to keep those working too!
i'm looking at the Kenwood DNX9960 or the DNX6960.......can't decide on the voice control!
It seems like the wiring harnesses (like the PAC OEM harness) used to replace the head unit has a separate box that plays the chimes and blinkers. Is that accurate? Does it sound the same as factory or does it play it's own sounds for the chimes?
I am in the process of installing a Kenwood DNX5160. Everything I have read says that yes the harness will still allow for OnStar/emergency signals. If you use the metra harness for this, though, you will lose turn signal sounds without a separate relay. XM will not because Kenwood no longer supports XM. Steering wheel controls will still work with a separate unit.
http://www.crutchfield.com/S-I7FuHIFBZyj/c...sp?I=120OSLAN01
If you are going through crutchfield when you add the HU to your cart it should automatically ask your if you want to add this. It will be $64.99 since you are getting a HU over $100. It should also add something to retain your turn signal sound.
And I know there is a something to retain your XM. I would call crutchfield, they are pretty good at knowing exactly what you need.
I have a Kenwood radio in my 2010 work truck and had to use the module to keep the chimes and turn signal sounds working. They don't sound exactly the same as stock. The sound doesn't come from the speakers anymore - it comes from under the dash where the module is. It all works OK.
I forgot to mention you can keep the stock xm with an older model such as the 6140(2009 model). As of the 2010 models which is the --60's XM is no longer compatible for control through the head unit. You can purchase a seperate tuner and put it in through the AUX but if your like me and want everything clean and to go through the head unit, just lose the XM.
  • 5 months later...
I too am interested in the 9960. I watched all the videos on youtube about it, looks really clean. I do however want to retain my XM, it's all I listen to in addition to my ipod.
I'll put out my intentions and someone cna answer if this (or any unit) will meet my criteria.
1 - I want to hook up a huge hard drive via USB or any other connection and have all the contents accessible through the touch screen. The HD will contain approxiamtely 70 GB music, and approximately 600 GB of movies and tv shows ( i do A LOT of road trips)
2. Retain XM functionality and have it accessible through the touch screen.
3. Retain steering wheel controls and bluetooth
4. Have NAV available, and if possible, have the funcionality to use that NAV while driving, this may require additional products which I am willing to install, just don't know what they are
Suggestions?
I have since learned that the 9960 is easily bypassed by grounding the parking brake wire. There is also an additional piece of equipment for XM Sat Radio, and retaining steering wheel controls.
so I guess the only question remaining is question 1, any help?
    ncleg
    ncleg
  • Who's Online   0 Members, 0 Anonymous, 1,530 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
