Water Leaking.
My driver side floor is soaked everytime after a rain storm and i've pinpointed it to coming in somewhere around the door jam, A-pillar area. Cant seem to find out exactly where tho. It runs down and gets under the plastic rocker panel step and then makes it way over to the carpet, which absorbs it all.
Any TSB on this or recalls?
2006 2500 hd, thanks.
Do you have cab lights, I do and mine were leaking doing the same thing. I just put some sealant on them and put them back up there. Could also be XM or OnStar antenna.
I have cab lights, and last night I tried to pin point it with a hose and tore all the trim pieces away so i could see. Welp looks like I gotta wait for it to rain because I cant find anything.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
