Fuel Pump Question
2003 Suburban, 2500, 6L, 250,000Km, two fuel tanks (one on driver's side and the second a pillow tank above spare wheel.)
Just recently been hearing a loud moaning sound from above the spare wheel area, in addition to the typical whine from the side fuel tank pump. Notice the engine stumbled a bit, while simultaneously hearing the moaning sound stumble.
I guess the second tank's fuel pump is about to die, right?
Which pump is primary in feeding the engine?; the side fuel tank pump, or the back fuel tank pump?
Could I just electrically disconnect the secondary pump and keep driving with the side tank?
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
