Dome Light Replacement Help
Can someone on here please tell me how to remove the console that houses the dome lights in a '07 GMT900 Silverado? I have a few of the trim snaps loose but I still can't get the overhead console loose. I'm am pulling to the point that the plastic is popping, so I stopped. I don't want to break a $100 piece of trim to replace a .50 bulb. Any ideas how to get it loose?
If you are referring to the front Map dome lights I just removed the actual clear lenses using a credit card and then accessing the bulbs that way. Just have to make sure you don't break the tabs holding it in place. At first I did try to remove the whole console but realized it wasn't gonna come off so went the lens way. For the rear lights I have the dvd player and got the lens off the same way. Hope this helps.
