1994 c/k electrical problem....
ok... got in my 1994-1500 today after work... noticed I did not have a working radio when I turned the key on... started the engine and proceeded to drive home while checking things out... non working items are cigarette lighter, aftermarket radio ( non factory JVC ) and interior dome light( bulb is good ) everything else works fine, all fuses are good.. what should I look at... the last area I touched before leaving the car when I got to work was the cig lighter, am I correct in assuming I should start their before anywhere else, as I have been thru the fusebox.... also the fuse box floats loose under the cover their? is that factory? i do not see anything missing screws ect... I am going to take the glove box out and look behind the dash their as the aftermarket radio is in just under the center air vents in the dash... nothing smells burnt ect... strange... any info is greatly appriciated...
Tony
                1994 c/k 1500 4.3-V6 AUTO/AC/PB/ABS :angry:
Tony - the fuse box should not float, it should attach under there somewhere. Ok, I just went out to look at mine, the fusebox should have a clip on the bottom and attaches to part of the plastic piece under the dash. Since there is more than one fuse running those things you mentioned, you may have a loose connection on the back of the box??
Sorry I'm not much help
