Gm Advanced Remote Start
HarryK
My 2010 Silverado Reg cab WT 4.3L 4WD has the AU0 keyless entry...I ordered the Advanced remote start for it (17802087)...got it for $250 but dealer wants $214 to install it...it looks like it has the hood latch sensor and a new module ...is this something I can do? I've put in the DIC replacement panel with switch and have installed stereos in my youth many times....also a couple of alarms...If so...what should the dealer charge me to reprogram the remotes?
Thanks!
You can do the install your-self, but you won't be able to activate the new remote (and your current one will stop working).
you'll need the dealership for that.
I know this as I installed my own just this past weekend, and the local GM dealership wants 1.5hrs to program it. Not sure how much more time they would want to install it. Not cheap.
OK Pat thanks..I'm going to go with the install at the dealer...figure I made up a little on the price when I got some accessories at wholesale from them..
Thanks
