Dominator Ii Side Steps
Are these side steps for the 4 Door crew cabs the same as the extended cab for a 2010 Sierra/Silvy?
I'm asking b/c their is a pair for 330 shipped on ebay, but says its for the crew cab.
The site I bought mine from asked if my truck was extended cab or crew cab. I would imagine they would be slightly different seeing that that the crew cab back seat is 6 inches bigger than the extended cab. BTW I bought my steps for 337 and free shipping.
they are different for crew cabs.
JRL, did you get the black or stainless ones? im contemplating getting the black ones down the road....
I got the black ones from www.realtruck.com
The crew and extended are not the same
I love my black ones
Does anyone know where you can view the installation instructions for the GMT 900's. The Go Rhino site has installation instructions but they didn't show any drilling and from what I understand you have to do some drilling to install these steps. I want them but I would like to see what I'm drilling before hand as I actually plan to install them myself for a change :lol:
Does anyone know where you can view the installation instructions for the GMT 900's. The Go Rhino site has installation instructions but they didn't show any drilling and from what I understand you have to do some drilling to install these steps. I want them but I would like to see what I'm drilling before hand as I actually plan to install them myself for a change :cool:
I did no drilling. Holes are already there. Just bolt them in. At least for my truck that's how it was
  • 1 month later...
Old thread but I just wanted to post somewhere that I ordered the Dom II's last night from Real Truck.
Congrats! Now all you need is tow mirrors and a colormatched front/rear end.
AND A NEW FRONT PLATE
:tear:
Welcome to the club!
    Gkistler
    Gkistler
  • Who's Online   2 Members, 0 Anonymous, 893 Guests (See full list)
