Engine Swap
sorry if im in the wrong section did not see vans, i have a 2001 gmc 2500 van with a 4.3l, motor is done cant find another used 1 if so to pricy, found tons off 2003 to 2007 4.3s, what would be the changes in these engines, what do i need to do to make it work in a older van thanks guys
wait a few minutes i'm sure 2001Silverado364 will have an answer for you
thanks
