Weird A/c Problem, Help!
So today I was working on my 98 silverado z71 and I took the battery cable off as I was trying to find the source of a radio static issue. The truck was off when I did this and later I put it all back together. I then left the house and noticed the a/c wasn't working. It was only blowing hot air, and only from the floor vents. If I shut off the switch, I have a manual climate control, the a/c and recirc buttons are lit up. The second I turn on the blower they shut off. I have never had a problem with the a/c in this truck and it worked last night and earlier today. I have tried resetting the system by disconnecting the battery, turning it on for 1 minute, starting and idling for 5 minutes then driving and nothing seems to be working. I also replaced the a/c pressure switch that's located on the condenser on the passenger side firewall and nothing changed. The only thing I did today was unhook the battery and now the a/c doesn't work. Any ideas???
Try this procedure next.
Remove the HV ACIECAS fuse for a minimum of 10 seconds.
Re-install the HVACIECAS fuse.
Start the vehicle.
Wait 40 seconds for the HVAC control module to re-calibrate.
Verify that no DICs have set as current DICs.
The compressor will turn on and off but only when the blower is set to the off position. If the A/c and recirc buttons are pushed in and lit up then the compressor will cycle. I have tried almost everything, and nothing seems to be working. If I turn on the blower after the truck is running, there will be about a 2 second burst of cold air from the vents, then it switches to the floor and immediate heat. I have searched all over and don't seem to be getting any answers.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 910 Guests (See full list)
