2006 Sierra With Aftermerket Radio
I installed a Clarion nx409 in my truck about two months ago. To retain the factory chimes, i had to purchase a harness with the built in chime aswell. The radio works just perfect, the problem is with the chime box.
Whenever I click the key forward once i can hear a static nose coming from this box, it almost sounds like i'm listening to the radio but only getting static. The box will continue to make this static noise untill i start my truck and buckle my seatbelt, and it stops. Untill about two seconds and starts back up again.
I've already replaced this chime box three times, ad may have to replace it once more again. They only seem to last roughly 2-3 weeks till they need to be replaced. Not good considering the price tag of this (~$45). Although Canadian Tire is great for returns, i'm getting tired of having to open up my dash every now and then to replace it. Am I doing something wrong and how can I fix this?
I'll record a video and post the link to it to show exactly what is happening.
The part number is - E2 (scosche) Interface ('03-up) EGM2KF
:P
heres the video I said I would post. Hopefully somebody will chime in with a solution for my problem!
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/watch?v=RjEWfdrrTQs?fs=1&hl=en_US"></param><param'>http://www.youtube.com/watch?v=RjEWfdrrTQs?fs=1&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/watch?v=RjEWfdrrTQs?fs=1&hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Youtube
  • 3 weeks later...
I called customer support tonight and solved the issue (for now at least). I had to do a "master reset".
Was the master reset on the stereo?
Just wait till it gets cold. I have a Scosche chime box on my 06 and it constantly hangs up in the winter when the temps drop below 32F for an extended period of time. The interior lights and radio will stay on until I "master reset" the box or just pull the fuse under the hood for 5 seconds (clearing all settings on the HU too!). The box I have also randomly shuts off sometimes while driving. After chatting with tech support several times, I am convinced that this is a common problem they don't really care about it. I've been thinking about getting a different brand box before it gets cold again.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,296 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
