New Member From Ne Oklahoma
tomculver
Hi Ya'll, We have a couple of GM Trucks. I drive a 2008 Chevy Silverado LT 3500 DRW, Silver Birch, Duramax/Allison, Crew Cab, 4WD. I've added the K&N, Gatorhyde Bed Liner, B&W GN Hitch, and Black/Silver Naugrahyde seat. My wife drives a 2008 GMC Yukon Denali, Stealth Gray, AWD, with all options. I've already found the forum to be very helpful and look forward to learning more from you guys and hopefully can contribute as well. Yes I will try to get pictures posted soon.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
