Belltech Springs
Just wanted to know if anyone has used them. Yeah I know spindles are the way to go but that isn't the purpose of this thread. I'm looking for feedback on ride quality after installation. How much drop is it? Thanks.
Does anyone have any experience with lowering the front of a silverado with any particular brand of coils?
we dont do that here
So is this a " No Lowered Suspension" forum? Yeah whatever. Anyway, apparently my truck came with a more heavy duty suspension and rides like hell. It all lies within the coil and leaf springs. So I just want to change things to improve ride quality. In theory "lowering" with just coils isn't a good thing because the geometry of the original suspension is being changed. My goal isn't to lower my truck, but to improve the ride.
