Window Gets Stuck
terryjason
thanks for reading i have a 01 sierra recently when i attempt to crack the drivers window it will roll all the way down fast and hard .it will not roll up unless i shut me key off open the door then turnthe key back on.could this be fixed by deactivating the auto roll down is that possible
