Escalade Ext Tail Lights
Just curious why the EXT comes with standard halogen bulb tail lights whereas the SUV's come with full LED tail lights? SUV tails wouldnt fit in the EXT would they?
LOL. Yes, I don't understand why they would do this...its still a Caddy. I can never understand the things they do!
LOL. Yes, I don't understand why they would do this...its still a Caddy. I can never understand some of the things they do!
Yea me either. I also fixed that up a little bit lol!
i almost failed school but hey i graduated.... so i have hope for the general
well i was in a vocational class at a different location so i had to leave 3rd period half way thru so i can learn about them john deeres. i think im gonna paint my 4.8 john deere green
i want to dress mine up but cant pick a color to go with the grey.
im probly going to match it to the truck color. incliding the engine cover
Ok ---- Hijacking back on topic..... :cheers:
The EXT and Avalanche share the same tail light bezel. The EXT looks like LED but isn't. Escalade and ESV tail lights as well as Tahoe/Suburban/Yukon are not compatible with Avalanche/EXT.
Good question why EXT are not LED. Maybe volume is not high enough to justify LED tooling? Lets hope the 2011/2012/2013 models get LED, so we can retro fit them!!
