1-2 shift shudder SOLUTION
I have the condition described in the following TSB. I did a search and read several of yous guys do also. The dealer tells me the parts are on "national backorder". that was 3 weeks ago. Could somone who has this problem also, see if there dealer can get them. i think my dealer is jerkin me around. thanks! :( Or ifa anyone can check the part #s for availibilty that would be excelent.
Transmission 1-2 Shift Shudder, Vibration, Slips, Chuggle (Install Generator Voltage Sense Circuit) #02-07-30-030
2001-2003 Chevrolet Silverado
2001-2003 GMC Sierra
with 4L60-E Automatic Transmission (RPO M30)
Condition
Some customers may comment that the transmission slips, a shudder, chuggle, or vibration is felt when the transmission shifts from first to second gear.
Cause
A 12 Hz electrical feedback from the charging circuit may be affecting the transmission pressure control solenoid, causing a fluctuation of the line pressure within the transmission.
Diagnostic Tip
Road test the vehicle under the following conditions:
Throttle position is less than 15 percent.
Engine coolant and transmission fluid are at full operating temperature.
The outside ambient temperature is warmer than 24°C (75°F).
If the condition is present, disconnect the generator 4 cavity connector (2 wires in the connector) and retest.
If the condition is no longer present, perform the correction listed below.
If the condition remains unchanged, the condition will not be corrected with this procedure. Look for other causes of the condition.
Correction
Install an external sense lead to the generator assembly. This is accomplished by adding a wire from the generator four wire connector to the generator output BAT terminal.
Disconnect the negative battery cable from the battery/batteries.
Slide the protective boot on the generator BAT terminal aside and remove the retainer and wire cable from the BAT terminal.
Unplug the generator 4-cavity terminal from the top of the generator.
Remove and save the orange weatherpack seal and CPA from the 4-way connector.
Using the proper terminal removal tool, remove the two wires from the 4-way connector.
Install a red cavity plug, P/N 12059168, into cavity "A" of the new 4-way connector, P/N 12186568.
Install the brown (Circuit 25) wire of the vehicle wiring harness into cavity "B" of the new 4-way connector.
Install the gray (Circuit 23) wire of the vehicle wiring harness into cavity "C" of the new 4-way connector.
Obtain a piece of 0.80 mm/18GA black wire, 254 mm (8 in) long.
Install a red terminal seal, P/N 12048086, and terminal, P/N 12048074, (crimp and solder) on one end of the new black wire.
Install the new black wire into cavity "D" of the new 4-way connector.
Reinstall the connector seal and CPA, from the original connector, to the new connector.
Plug the 4-way connector into the generator.
Route the black wire to the generator BAT terminal, sliding the wire into the small end to the output terminal boot, along side the generator output wire.
Crimp and solder the ring terminal, P/N 02977821, on the open end of the new black wire.
Place the generator output wire and the new black wire onto the generator BAT terminal and install the retainer. Tighten
Tighten to the BAT terminal retainer to 9 N·m (80 lb in).
Connect the negative battery cable. Tighten
Tighten the battery cable retainer to 17 N·m (13 lb ft).
Parts Information
Part Number
Description
Quantity needed for this repair
SPO Dealer Cost
J 38125
Kit Tray Location
Available from Kent Moore (approximately $12.50 per pkg)
12048074*
Terminal
$0.57
Tray # 2
50 per package
12059168*
Cavity Plug
$2.00
Tray # 3
25 per package
12048086*
Wire Seal, Red
$2.05
Tray # 3
25 per package
02977821
Ring Terminal
$1.50
Must be ordered from Parts.
N/A
12186568
Connector
$1.30
N/A
Part numbers shown above which have an (*) are found in the terminal repair kit, J 38125. They may be ordered either from GMSPO or SPX Kent Moore.
Parts are expected to be available 8-15-2002 from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
*N8505
Rewire Generator, 1-2 shudder
0.7 hr
*This is a unique labor operation number for use only with this bulletin. This number will not be published in the Labor Time Guide.
