Cluster Bezel
I am wondering if anybody knows if they make the plastic bezel in titanium with the chrome for just the 4 gauge setup I don't want to switch to the 6 gauge style I just like the look of the titanium with chrome better.
You could just buy the 6 gauge bezel. The 4 gauge bezel doesn't come in titanium or chrome. But if you don't change the gauges as well then you will have 2 empty slots on the bezel
Heh, I thought about stealing the gauge cluster out of the new 1 tons at my work, it is so much better than black, is it possible to get the 2 extra gauges to work.
You would have to buy a whole new cluster. Then after that you would have to get the cluster programmed to your truck to read the correct mileage and what not. To do that you could bring the bezel to the dealership who would then ship it off to a company who does it. Or you could just send it straight to the company yourself.
Stealing... stupid :D
Stealing... stupid :P
Hey I didn't say I did I said I thought about it, thats not a crime! :D
I guess its not even worth it moneywise, I'd only do that to get the oil pressure, as the trans temp is on the DIC.
I could just install a small oil pressure gauge if I felt the need for one, which I don't.
the other gauge isn't trans temp, it's a volt meter
the 6 gauge cluster has Speed, tach, oil pressure, engine coolant temp, volts and fuel
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
