Backup Camera Info
Just finished an install of 7 inch aftermarket touchscreen and backup camera.
The camera was an XO Vision HTC35 (35 bux) and I installed it like Bostonsfavson instructed minus the trim of the plastic piece on the bumper.
http://www.gm-trucks.com/forums/index.php?...1&hl=camera
Instead of the stabilizer block he used and the cut out of the plastic, I used a black sway bar bushing by Duralast (FA7153) from AutoZone (8 bux). The camera fit snug. It was perfect. I had to trim the bushing to fit into the space above the hitch, but the hole for the camera was like it was made for it.
I will post pics later. Just thought I would supply some info for future modders.
  • 4 weeks later...
Wheres the pix :lol:
Was also curious how you mounted the 7" monitor as I am going to be doing this same setup. Parts are on order.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
