Another Brake Thread
*ATE PREMIUM ONE ROTORS*
Well Canadian Tire has em' on sale, I might buy them to have on hand for the future brake job that is destined in the next year or so.
My factory rotors have warped twice (had em' turned after first pads burned out at 64,000kms), I think on the passenger side my caliper is sticking a bit (And yes I greased the slides! Still sticking!) SO I'll replace the calipers as a pair also when the time comes for new pads again, but thats another story anyways..
Anyone heard of these rotors? Are they any good? I can't seem to find alot of solid reviews that relate to my vehicle. Would it be an upgrade???
I'm sure its not just me (or is it?) these GMT-900 brakes are sort of junky...
Drums... on the other hand... SOLID :D
Any input is appreciated Thanks!
BTW I'm not super hard on my brakes but I should be able to if need be!!!
2007 GMC Sierra 1500 W/T 2wd 4.8 auto reg cab @97,000kms
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
