For both of those I think you'd have to get them painted. I've never seen a matte black grille and no one sells painted gmc emblems. You could get a vinyl overlat for the GMC or get it painted or paint it yourself. I bought a black mesh grille and my truck is carbon metallic, so not totally black, and I have matte black wheels. I really thought about having my grille painted to match the wheels but decided not to. I may go back later and do it though. But that is my suggestion.
