Travel Trailer Towing Problems
lw0023
i have a 2008 GMC Sierra extended cab with factory towing package. Am pulling a 28 Foot Feather Lite JAYCO trailer that weighs about 5500# dry and I have a maximum of 1000 pounds on it. Have equalizer and sway control hitch. Everthing seems to be hooked up ok and trailer is level and pulls rather easily. However when at high way speeds the pickup reqires constant steering to keep it "smooth' -- it wants to migrate side to side. Any ideas.
Not enough tongue weight, weight distributing hitch not set up properly, or one of the trailer axles is out of alignment. I have heard of the axle problem coming from the factory. usually there is abnormal tire ware.
I would bet on one of the first two...especially the hitch not being set up properly, sounds like the front wheels of the truck are not being loaded enough. Check the front fender well height un hooked and hooked up to the trailer with a full load. Equalizer says that the height should be the same or not more that 1/2 inch higher.
Agree with above, #1 and #2 probably.
I tow a 29' dual-axle travel trailer, with the same hitch set up, sway bars, etc. About the same weight too... and no problems. (2008 SLT w/ towing package, elec brake, etc.)
My trailer is of similar size and weight as yours. I also use an Equ-l-izer hitch with the 1000# bars. My rig tows effortlessly. My guess is that you have a problem with not enough tongue weight and/or not enough weight distribution to the front axle. The tongue weight should be 800-1000 pounds idealy. The weight on your front axles should be roughly the same as when the trailer isn't hooked up. My tongue weight is 900# and my front axle is only 140# heavier when the trailer is hooked up.
You can usually weigh your rig at a truck stop. It costs me $9 to weigh at the Flying-J near my house and that's for two passes. One with the trailer hooked up and one without.
I agree with not enough tongue weight. I have an 08 crew cab with the factory tow package towing a 21' travel trailer. It is amazing the difference 1 link up or down on the chain for the stabilizer bars will make.
++1 on tongue weight. I tow a 7k lb camper w/ over 1000 lbs on the hitch before connecting the WD bars (~900+ lbs on the truck w/ the WD bars). It pulls very smooth and stable and is maybe ~0.5" lower in the rear than front w/ 1200 lb WD bars. Can't overemphasize tongue weight and WD system enough.
This could be as simple as underinflated tires on the tow rig. When towing heavy do you add air to the tires?
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 703 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
