Passenger Seatbelt
When my girlfriend is with me it seems that her sealtbelt locks up when we hit anything in the road, bumps, potholes, and especially railroad tracks. She has to undo the belt and lock it again. I never have a problem with mine. Has anyone else run into this problem?
My 02 passenger side locks all of the time too, had the whole thing replaced and it still does it, I did find somewhat of a solution though! If you go by the dealer and pick up the free seat belt extender, it will fix the problem or at least it did on mine! It says to only use them if the original belt isnt long enough, (Which the original belt is long enough)! So I guess it is a wear at your own risk type thing, but does work and is WAY comfortable. Keeps me from getting a seatblet ticket whenever I have a passenger!
Thankfully, the passenger belts on my truck only lock up when they get over-extended to the rachet point.  (You might want to check if she's doing this and not realizing it.)
However, because I've seen this problem in other trucks without over-extending the belt, I wouldn't let the dealer replace my good belt when the little button broke that keeps the tang up high when unfastened.
My 98 X cab on the pass side was doing the lock up thing on the old lady(I told her that she was to fat)no really,I took It apart and there is a weight deal(that sences the truck coming to a stop) that musta been hanging up,I removed the assy. from the door and fooled with it.made sure it was working right and it hasn't done it anymore.I guess that slamming the third door screws with it. :nono:
A big ditto here.  Both of mine do it...but I think mine is worse.  It becomes a royal pain in the arse...especially when I lean foward to look for cars at intersections.  I've also had mine looked at & replaced....no difference.  Dealer states that is normal for seat belts such as the ones in the Silverados...not sure if I buy that...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
