If You Could Get Any Size Bridgestone Or Firestone?
bandaman
Ok, I was highest bidder on a set of 4 tires.....any size Bridgestone or Firestone that I want. I was planning to get 285/70R17 Firestone Destination M/T, but now I am wondering if I should "upgrade" since I got a good deal.
Truck is 07 GMT-900 Silver Birch Crew Cab SLE2 with 2" skyjacker leveling kit and stock 17" alloys.
I could go the same M/T tires in a 285/65R18 and get some new blingy wheels or I could buy some 20" wheels and go with a set of performance tires or some A/T's.....
Decisions, Decisions...
If you had to chose what would you get?
I would go with the 285/70/17 Destination MT. They will look much better than going with bigger wheels. Big wheels do not look good IMO, especially with a MT. On another note, the Destination MT is supposed to be a great tire and they look GREAT. I have been debating a set of those or Goodyear wrangler duratracs for my next set of tires.
Thanks for your advice....I have been leaning the same way....on a 4X4 I prefer more sidewall and less wheel....gives it a more offroad aggressive look I think....plus it adds some more capability or durability I think for off road and farm use. (I do little farming on the side) More sidewall equals less chance of scraping the wheels on curbs, or flat spotting on potholes.....plus the tires are more plentiful and cheaper in 17" than the bigger sizes.
so, probably go with the 285/70R17 M/Ts on stock wheels for winter......if I love them and the noise and wear is good, I might swap to some nice chrome wheels in the spring......if they are not quite what I want, I'll make them my winter set and then go with a more street friendly tire for the good weather months.
I have to agree with everything you just said. Give the Destination MTs a try and see what you think. I've read really good reviews on them. Just make sure to keep them rotated, keep an eye on air pressure, and you should get pretty good tread wear. At least for an MT. Plus those tires look mean!
The Firestone Destination M/T was the mud tire I had decided to put on for the winter months to go with the 18'' wheels I had just bought. I read excellent reviews on this tire and was all fired up to get a set and was told they were on national backorder. Meaning nobody had them and they didn't know when they would be made again. In the sizes I needed anyway.
The guy at the tire shop told me about Micky Thompson MTZ and after reviewing them and also seeing good reviews this is the tire I bought.
The Firestone is a great looking tire though.
Indeed, they are on National Backorder.....expected production is Mid November...but who knows....I have the 285/70R17 Firestone Destination M/T on order....I just hope they get here before the snow flies. My stockers are near pull point and won't be much good in the sloppy stuff. If they don't get here in time, I guess I will be searching for a set of winter tires, stock take offs, or something...
    • Oh yes, someone is going to be certainly hitting up GM service/ support for a 20 year old truck.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
