Harsh Ride With Air Bags
So I have the Firestone airbags along with a 2" belltech shackle drop in the rear of my '09 1500, and the ride is really stiff! I have tried putting more air into the airbags with no help. Is this normal or am I doing something wrong?
Thanks!
Sounds like you are running too much air in them. They should be barely aired up when you aren't hauling a load.
I have tried running with them at 5psi and the ride is still rough. I am considering getting rid of the 2" drop and leaving the air bags in. Would that make a difference?
Airbags should not be contributing to a bad ride unless you have something binding up or they are installed where they have very little travel. I assume your truck rode fine before the bags?
Thanks!
This is the opposite of what most people do. Usually you "lower" the air pressure if the ride is to harsh. OR was this a typo?
Thanks!
Well when I had the airbags with 5 to 10psi in them the ride was really harsh so I tried increasing the air to see if that made a difference and it didn't. So no it was not a typo! :lol:
Wouldn't a shackle drop make the distance between the axle and the frame smaller? Even with 5lbs, the bags may be "smooshed" together acting more like a bushing then an airbag. Just thinking aloud here...can you take some pics?
That's what I am thinking. So maybe going back to the OEM shackle setup would bring the ride back to normal. Anyone got the OEM shackles and leaf spring spacers that they want to get rid of?? :lol:
