Anybody Dyno'd a stick 4.8?
My dad has a 2000 Silverado Z71 w/3.73s, a 4.8L, and a 5spd.  He had it dynoed with just a K&N FIPK and a single 3.5in mandrel bent exhaust with a hooker muffler, it made 242rwhp and 256rwtq.  The hp was still going up when the speed limiter came on.
What part of the US was this in? Winter, summer, temperature?
Just wondering... Thats pretty close too mine (249hp, 272torq, they said about 261hp if i was in 3rd gear). I guessing you did yours in 3rd gear, speed limiter and all..?
It was done in south-eastern WI, the temp was about 40deg, and I think it was done in third but I can't remember.  Do you have a 4.8 or a 5.3?  What where the condition when you had your truck dynoed, and where was it done?  Thanks
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
