What Size Can I Fit
TX HOG
i have a rough country leveling kit for a 2008 silverado. i plan on getting 20" xd spy wheels. what width, offset and tire size should get?
20x9 with a +18 offset and you can run anywhere in the 32-33 ish range for tires like a 285/55/20 would be a good fit you could probably go a bit wider but you may need to trim some
Well, the 20x9's only come in a -12 offset so I would opt for the 20x8.5 with +18mm offset (which is pretty close to stock). And a 285/55 would probably be a safe bet on those wheels.
