Bolt Pattern
yukon25008.1
Picked up an 87 25' camper and the tires are shot and the wheels look horrible, whats an easy way i can measure the 5 lug pattern to see what it is?
the bolt pattern is 5 inch
thank you.. so its either 4.5 or 5.5 ?
the reason i was asking was i have a set of 5 lug wheels that fit on a 5 lug saab that are in great shape with like new tires on them
yeah for a 5 bolt, measure from the center of the bolt diagnal to the mid section between the 2 bolts across from it:
it will be either 4.5 or 5.5.
as for your SAAB wheels, the only question other than lug pattern/spacing is does the hub size match.
it fit..kinda.. the bolt pattern fit but like you said the camper hub was slightly bigger then the hole in the rim
oh it's a trailer.. sorry, thought it was an RV..
here you go:
http://www.tjtrailers.com/store/wheels.html
It must be a American thing. In Canada a camper mounts on your pickup box, a trailer you pull behind.
not an American or Canadian thing, it's just a people thing.. I call it a trailer, he calls it a camper, ain't no big thing.. some people call it Soda, others Pop, and still others Soda Pop..
it's a tomato, tomahto thing.. who really cares, as long as he got his question answered..
thanks again for your help.. as far as words.. a trailer is a trailer (mobil home) or a tool you haul things around in.. landscape trailer,utilty trailer.. in this case i guess its a travel trailer..pull along camper..whatever :P
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 285 Guests (See full list)
