2001 Blazer Lt 4.3 4wd
mikewood31
anyone every have this happen?
on there s10 blazer
we have owned the truck 2 weeks been in and out of 4 high
no problems.one night it wouldn't start had all lites and wipers
waited 1/2 hour tried it ,it jumped forward but started right up
and I noticed a bit clunky going into gear
drove fine for 2 days waiting to get it in to GM to have it checked out
put the scanner on it ,no codes,no check engine lite battery connections clean tight
14volts at the battery running ,4x4 switch operates fine, engine runs smooth
then yesterday on her way to work she was in 2WD
heard a scrapping sound when she turned left
the front wheels locked up! she said it felt like 4Low all the sudden
again no check engine lite, 4wd switch operates no problem
she pulled off and stopped right away
and we had it towed into the dealer
now we are just waiting for the call$$$$$$$$$$$
its almost un bearable to tell you the truth
Im thinking hubs,cv joints,transfer case
the worst of course
I have never had this happen on any of my 4x4's
the prevoius owner replaced ball joints and drivers side Hub in august of this year
as well as front rotors and calipers & pads and did an alignment
and gave us all the bills for everything he had done on it
so Im kinda lost as to why but I guess the lurching forward was my warning
update !!!
nothing wrong with the powertrain
turns out 3 out of 4 of the brake calipers were put on wrong
at canadian tire one came off and wrecked a rim but thats it
the previous owner took it there for brakes which I would never ever do
fellow canadians take note!!!!!
I will be taking this matter up with them believe me
serious saftey issue here
I just never got it in to GM for inspection fast enough
our new little chevy is going to be fine
and from here on in nobody but GM will touch this truck
Thanks Rob
being a tech,do you think GM will give me a letter stating improper installation
causing damage or will they just show what they did to repair it on the work order?
Crappy tire says we have no warranty because it is not transferable to us, the previous owner had the work done not us in august
warranty ? does he actually think I would try to take that truck back to them or any vehicle for that matter, Ediot !! My children were in that truck 8 hrs earlier you half assed jerk off
if chevy will back me up Ill slap him with just the repair bill if hes lucky and not go to my laywer
