Lift Question
Fellas im thinking about adding a zone 1 1/2 body lift to my truck. i dont want anything super high off the ground so modest will due for me. i have 20x10 custom rimms that i need to get new tires for. what are the biggest size tires i should be looking at?
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
