Front End Chirp
Having trouble finding where this noise is coming from. It is an 2001 1500 Silverado. I have a high pitched chirping noise around the area of the left front tire. It speeds up the faster I go and only makes the noise under a load, when I let off the throttle the noise stops and comes right back as soon as I give it more throttle again. I had both front wheel bearings replaced a month ago and that didn't help. It has also started making a noise like something is binding up and popping when I make a turn with 4 wheel drive engaged and seems to be coming from the same area. Thanks for any help.
What kind of surface were you on with the 4x4 engaged? An engaged 4x4 will bind on dry/hard surfaces that don't let the front wheels slip/spin as they turn. Have you considered the chirping noise being engine/transmission/exhuast related since it only occurs under load and when your on the throttle?
I was on ice. We had a hell of a batch of freezing rain here wed. night. I have considered the engine idler pulley, tensioner etc...but I am pretty sure it is coming from the front tire area. If I hadn't just put new brakes on a couple months ago I would suspect them it kinda sounds like a brake squeal only it chirps. I might have to break down and put it in the shop and let them take a look at it. It's got me baffled. I have jacked the truck up and checked for play and checked cv and u-joints, only thing I have not checked is bushings (sway bar maybe). Thanks
