My door isn't opening from the inside?
Well, I took the door panel off and I thought everything looked okay.  I can't see that much, I pulled the plastic away a little, but I can't see behind the metal or whatever.  Anyone else had this problem, if so, how can I fix it?
I hope this doesn't sound silly but have you looked at the Child lock out?  Of course assuming you have a 4 door and its one of the rear doors.
Not silly at all.  Though I wouldn't mind a 4 door, it's only two.  That's something I'd do though.  lol  I still haven't figured it out.  My truck looks really nice until I roll my window down to open my door.  hehe  I'm gonna take it apart again and maybe look at the pass door as a model and see if anything is different, off track, or something of that nature.
what year?
if 99+  take the door panel off and make sure ever metal rod is securely in place in the plastic holders on the inside handle and the locking mechanism
Well, it's a '95, not a 99+, but hopefully they're similar.  I'll check that, my wife had a Grand Am that the rod came out of the clip on her door and we fixed that.  I hope it's something as simple as that.  If not, I'll be back on here trying again.  Thanks for the help guys. (and gals maybe?)
Well, to add to my problem, the handle broke off today.  Unbeleiveable.  Guess I'll be picking up one of those from the salvage yard as well.
Yea same thing happend to my 1997, I had to get inside the door. remove the cover, then there is big holes in the metal backing you can fit ur hand through, On the other side I saw there is a metal rod that goes into the handel directly behind the part u pull. This slide out , I finagaled it for a bit to make sure it stayed in. Yea i know how u feel. My trucked looked all nice.... then i would pull up and roll down my window to open the door . I was also having tranie problems then to, so I had go under the car to put it in park, then start.. felt real ghetto in my new 20,000 car.
Cool, thanks a million for the info.  I'll be contacting my local junkyards for a replacement handle tomorrow and we'll be fixing it on Wed as I'm off work.  I might holla back if I think of anything else or run into probs.  Thanks again man!!   :cheers:  :lol:
i had a similar problem, i took it back to the body shop that failed to reconnect some type of rod, and voila, she opened from the inside....mine is a 95 also!!!!! check behind the pull handle also the rod may have become disconnected there! :lol:
    250.3k
    Tiffanyrose
    Tiffanyrose
  • Who's Online   4 Members, 1 Anonymous, 1,112 Guests (See full list)
    • I tried tapping it.  This might sound like a dumb question, you should feel vibration or some type of noise when it turns on? Can someone please verify? Thank you all!
    • I feel better now for my own view point and actions or lack there of towards the dealership service theme reading your post and others. GM corporate is who offers the two free oil changes on the HD trucks and I bought my truck in Feb of 2025 and those oil change offers run out within 2 years I believe and I highly doubt I will be using either one of them. I had asked if I could officially give those free services to another customer ( a friend ) and they said no, its all a GM corporate thing based on the vehicle in question. What that service advisor did however was go into a little story about how such and such customer was denied engine warranty because he had done his own oil changes because then they are not documented ... you see where that goes and so an employee playing the game of scaring the customer into having the service work done there most certainly triggered my thought process. At a later date I did talk to the person who handles warranty claims at the dealership and she said to be sure to document the oil changes and keep receipts for the oil and filter ( coped the receipts from cases of Mobil oil and case of filters I bought from them ) and the vehicles VIN, the date of service, mileage etc and staple that together as a record I would give them if that was ever needed and I keep my own log book for services for each vehicle as well. Oh and about 8 months after I bought the truck the dealer starts calling me to offer a maintenance service since they haven't seen my vehicle show up on their system ... for the mere fee of 300.00 Canadian to change the oil and rotate the tires and a few other minor checks and I declined the offer, I get the call again a couple of months later for the same thing and she could tell I was not interested and she asked if they should take my name off the call list and I said yes, do that !.    By the way did you happen to keep your factory oil filter to open it up and see the surprises inside as I expect some will show up as per the odd little sliver of metal shaving and particles that the filter does trap along with bits of grey silicone sealer that come off of the inside edge of mating surfaces. I have cut open every filter so far on my truck although few miles but have changed the oil often and the second filter was vastly better with very little of anything, that first filter was the unsettling one as I expected it would be.
    • I get why they do this…but man…not ideal. I only extract on inboard boat engines because the drains are buried and even then I hate it because it’s easy to leave a quart behind with that method.   They should market it as an “oil refresh” not oil change!
    • I only get oil changed where I can watch. Valvoline pulls through the dipstick into a see thru glass. When done they show me the dipstick. About the only way they can mess up is using the wrong oil. But that secret wouldn’t stay secret long. Honda uses TQ wrenches on everything. You can watch through a plate glass window. Discount tires does that with tires. Trust but verify.
    • I would not argue that with you. It would be pointless to argue against the truth and you speak the truth.    My question and in fact the entire point of this thread is an exploration into the levers of wear which happens no matter how well we maintain our powertrains.    Some of these levers we exert a good deal of influence over which can and do result is lower wear, longer powertrain life. Some others we are sort of stuck with.    An engine is typically done when the ring to bore seal no longer is able to do the job effectively. Normally the first thing to go in a engine otherwise well maintained and adult driven is this seal.    Looking into the means, methods, products and attitudes that influence the rate of wear seems a worthwhile inquiry to me.
