Axle Swap From 3500 To 2500
I have a 93 c/k2500 with a 14 bolt srw i want to put a 14 bolt drw out of a 95 c/k3500 under it will it fit (bolt right in)? if not what kind of trouble will i run in to? thanks for your time
I cant say how in and out it would be. I could imagine that it would be a somewhat in and out swap outside of the fact that you will have extra wheels sticking out the side of your truck. i actually saw a suburban with the conversion done just recently.
some of the biggest issues you will face is the ratio and you might need to do a little drive shaft fab. job. the housing for the 3500 is bigger than the 2500 so you might have to chop the drive shaft. i know for a fact they are not a direct interchange but other than that there shouldn't be to many problems. i know that there are some differences in the rear end depending on wheel base for the 3500 but that shouldn't affect it if you are putting it in a 2500
