Noisy Air - Little Pressure
aerovez
My heat and A/C operate fine, however, there is a lot of noise coming from above the fan unit. It sounds as though one of the air directing doors is not closing all of the way and air is rushing by it. I can hear the doors move inside when I change from one to the other, but air pressure coming out of the vents is still very weak on both floor, dash, and front window. I have taken a video to help clarify. You can hear the fan humming, but its the rushing air sound that I would like to direct your attention to. Any ideas??? Video: http://www.youtube.com/watch?v=0aYugKnI_vM
just take'em out and reinstall the cover,
it was an attempt by GM that failed and they no longer use cabin filts
and the cost of them,
Found a step by step picture of someone else swapping them out. Just called over to Advance Auto and they have 1 left that i'm going to pick up after work. http://www.sparkys-answers.com/2009/06/200...ging-cabin.html
Hopefully this will solve the excessive noise problem too. From the pictures the filter is left of the fan, the excessive noise is coming from above the fan in the dash near the firewall. Maybe it's just backed up pressure? It's about 10F outside right now, this should be a fun swap :)
HaHa not the first time ive seen it, got a thick skin for the Habs jokes, french Habs fan playing hockey in Toronto will do it. although it is nice to watch my Habs play in the post season lol leafs fans arent so lucky lol OLE OLE
sorry Ty ,i had to show you this pic lmao
go leafs!!!
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
