Slight Vibration Need Help
I have a 2008 silverado 5.3 ext cab stand bed at one time I had a problem with my truck feeling like it was getting rearended at a complete stop.A gentalmen on here helped with that problem with a service bulletin which seemed to work.
But in the last 4 months I've noticed a slight vibration when I'm doing cruise control and it will deaccelerated for a second then be fine but on the deacceleration i feel a slight vibration.
I just put on Dynatech Headers and Corsa exhaust and now I really hear it when it does that.Could the u joint in the front torwards the transmission be going bad ?
K.I.S.S. first clean the MAF with some MAF cleaner. u have a stock air filter or K&N type?
I just put a K&N on when I did the exhaust.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
