I love my truck again!!!
Well Finally I broke down took off the front pass side door panel put some 3m tape and foam to stop this darn rattle i have in the very corner (top corrner of panel closest to ext cab door).
Drove it around and the noise is GONE!!!
JP thanks for your door removal instructions they were very helpful.  Only thing i noticed which wasnt on there is to disconnect the speaker wire.  Also for any of you curious people out there the bolt size (2) in the door is a 7mm.  Only problem i had was removing the power window/door wires.  Its one unit but i wanted to take my time so i didnt break it
:cheers:
I would be VERY interested in those door panel directions.  I need to pull both of mine off and examine where my rattles/noises are coming from.  Thanks!
Eric
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
