Upac-gm29 Ipod Interface $100
$100 + $10 shipping
This is an item that will integrate your iPod into your factory stereo. It's a simple plug and play design.
You can plug in your iPod to charge and control it from the factory stereo buttons.
This item also functions with iPhone - I used it for the iPod function and the Pandora App.
***Important***
this item did NOT work with my steering wheel controls - I THINK it has to do with my truck being an 09 with factory bluetooth, but I am unsure. Therefore I would recommend this only to people without steering wheel controls, although it may or may not work in 07-08 models without factory bluetooth, I have not tested it.
When looking at comparables online keep in mind that these will not work "out of the box" with updated iPhones or iPod touches (running os 4.0 or higher) without an extra microchip - MY ITEM HAS THAT INSTALLED ALREADY and is ready to go.
below is a stock photo and more info:
Features:
multi input media device
# compatible with select general motors 29bit gmlan radios
# 2 inputs support the following: ipod/aux ipod/hd radio or aux/hd radio
# ipod input can be used as full control from the radio or ipod
# works with both 6-disc cd changer radios and navigation radios
# optional hd radio tuner (upac-hdrt)
# full ipod control
# 3.5mm aux input and rca input
I also have the HDRT - which is the HD Radio Tuner available that will plug in to this unit, if anyone is interested in that we can discuss that too.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
