Finally Chased Down My Front End Popping
I have posted multiple times about a front end popping in my suspension when turning. After taking the truck to two separate mechanics who said my ball joints were fine, I found the popping to be a front upper joint on the passenger side. It is getting worse and worse and I am going to be driving about 2000 miles a month for the next 6 months so I think I need to replace it. It is tight when I try to shake the tire at 6 and 12, but when cycling the steering, I feel a bunch of popping/vibration in that arm. Therefore, should I go ahead and replace it before putting all of those miles on the truck?
It is a 2006 1500 crew cab 2wd. What joints should I use? I'm leaning towards Moog. Should I replace the arms with the joints, or do the joints press into the arm? Does anyone have part numbers or recommendations of where to buy? Anyone who has done this procedure that could lend some insight would be greatly appreciated!
