Aftermarket rim advise
I want to get some 22X10 rims for my 99Silverado EXT cab Z-71.  Will I have to do anything or will they just fit right on?  I want to get the ASA TRS II as seen on www.tirerack.com, any comments aobu those?
-KMT15
As long as they are 6 lug with a 6-5.5 bolt pattern and hub-centric they will fit fine and most likely roll alot better than stock.  My 20's handle and roll 10x better than stock, and the steering response is awesome  :cheers:
front will be a tad close against the airdam with that width and big tires..  cranking the tbar up or a lift will help ya out
whats an airdam?  this is a z-71, is that ok?  I need to go to tire barn ans dsus hi ththm to gt their opinions too
-KMT15
might want to shave a bit of the airdam to prevent from hitting.  My 20s rubbed.  Tires were 305 50 r20.
305/50's?  :cheers: I have 275/45's on 20x8's, they don't even come close to rubbing.  As long as you get a small enough tire they shouldn't rub.  You do have a Z71.
Tirerack.com recomends :305/40-22  tires, I have no clue what that means but...
-KMT15
    hotfish
    hotfish
  • Who's Online   7 Members, 0 Anonymous, 597 Guests (See full list)
