Ready Lift Problems?
i want to purchase the sst lift kit from readylift which lifts the front 4 and rear 1.75, it drops differential a little for the half shafts but would like input form others, especially if u have this lift kit, was also looking into the 5100's but would really like more lift, i dont do offroading except driving through pasture and dirt roads.
The short answer is don't waste your money. That kit barely lowers the diff, and does nothing to address the LCA's or TRE's. Search around this forum and you'll find plenty of info. Also if you check out GMFullsize.com. There is currently a thread discussing this.
save your money and get a "real" kit that drops the lower control arms. If you dont want to go that route, do a leveling kit (not more than 2" IMO) and add either a 1.5" or 3" body lift.
/thread :driving:
id have to agree with what everyone else is saying. especially for the price of the damn thing. either do something like a bds 4 inch kit. rough country 5 inch. or a leveling kit with a body lift. theres just too much stress on the components and something will fail considerably sooner than it should
/thread :driving:
i was always told that bodylifts were no good causes squeaking later, are there n e hydraulic filled bodylifts? what is ur take on the bilstein 5100 leveling shocks, also how complicated was ur rancho lift?
I was going to get the Ready Lift SST, until I read some of the comments about the kit in this forum. Now Im going with the Rancho 4" kit, nothing but good things have been said about this kit......you should look into it!
Let me guess, the same guy pusing the ReadyLift kit told you that? By the time they start squeeking (if they do at all), you're going to have more rattles in the truck anyway, so just turn up the tunes :driving:
Bilsteins are nice, lets you adjust the height to your liking to level out the truck's front end. Couple that with the body-lift and you're set. Plus I've heard good things about the ride, though I have never ridden in a truck with that setup.
I think I must have ADD, as my install took an entire weekend b/c I kept getting distracted. The install was easy, very straight-forward. I would recommend this kit to anyone who's looking for a solid kit... You really cant go wrong with any of the quality kits from BDS, Superlift, Fabtech, etc....
    250.3k
    chfkief
    chfkief
  • Who's Online   0 Members, 0 Anonymous, 1,557 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
